Nested Family
Nested Family
Nested Family
Hello, i have a problem with nested family. I did the adjustable wall mounted server cabinet. When you upload it into the project, for some weird reason door is not shown on the floor plan (visibility set correctly), but inside family everything is perfect. Best part comes when you go to the project 3d view, door is flying in the nowhere, but inside family on the 3d view it is perfectly attached. I have no idea how to fix it.
Any help would be super appreciated
Aleksei
dzanta
nested families within families need to be placed exactly where you want and the faces of the nested family and/or reference planes of the nested family needs to be locked to the correct reference plane of the host family.  From your images, it looks like the nested family is not aligned/locked in all views.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Tryied to go through it, seems like everything is correct. This family is done so you can change dimension according to your needs, the only thing that i cant set up this way is door. What else could it be?
Thank you for your help,
Aleksei
