Nested family Visibility control issue
sdonahay
sdonahay
I have a Mechanical Family (Strut and clamps) with a Nested Mechanical Family (Strut) in it that has a Structural Framing Family (a flat bar) nested in it.
The Structural Framing Family was created as a Mechanical Family then switched to the Structural family.
The problem is in the visibility of the Structural Member not following the Mechanical Family (Strut) visibility in the main family.
I placed 4 Strut families in the Main family, each facing a different direction. When I use parameters to set each one's visibility the strut geometry is controlled just fine. The nested Structural Family in the Strut does not turn off as it should. Pic 1 all Struts on, pic 2 all but one Strut turned off. See the Structural Family of the other Struts still visible.
Is this a known Structural Family issue or is something else going wrong?
Do I have to create a visibility parameter in the Structural Family and set up a chain to get it to work?
alan_eu
Hi @sdonahay
You will have to create the yes/no parameter inside the nested family and create another yes/no inside the 1st family and point this parameter to the nested one.
Probably you will have to create a shared parameter to do so (not sure right now, I need to test it before).
To control visibility on Visibility Graphics you will have to get all the families in the same category
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
sdonahay
