How to move modify parameters to edit type window?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
479 Aufrufe, 2 Antworten
Hi, in Revit connection, is there anyway I can move modify parameters from Properties to edit type window in Revit 2019? In Revit 2021, Modify parameters is already in Edit Type window so I can easily modify my connection and save it with a name and use it everywhere for the connection. but in Revit 2019, since Modify parameters is not in Edit Type window, I cannot edit my clip angle and save it and use it every time. I have to edit my clip angle every time. Please help me. Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
Jamhmer_Oc
als Antwort auf: Anonymous
Hi @Anonymous
Select the connection.
From Modify > Structural Connections tab > Connection panel select Customize.
You can save it as a custom one and reuse.
From the custom connection editor you will be able to edit the Double Side Clip angle settings and all the changes wil be propagated to all the instances of that custom connection
Jamhmer Oc
Nachricht 3 von 3
als Antwort auf: Jamhmer_Oc
Thank you. You the man.
