Nested Families with weird symbol Lines
sleepy_samoyed
Message 1 of 10
sleepy_samoyed
Hi all, I'm currently facing a problem regarding a ceiling mounted exit sign, when used in project and printed, the solid color looks pixelated.
Is there a way to fix this?
Thank you!
Replies (9)
Message 2 of 10
Maybe View Discipline-related.
Message 3 of 10
sleepy_samoyed
What do you think I should adjust?
Thanks!
Message 4 of 10
Change the View's Discipline.  If that doesn't do it, then post the file here.
Message 5 of 10
sleepy_samoyed
The family file looks fine itself and when it's loaded into the sheet. However, once it's printed as pdf, the lines appear as the screenshot above.
Please see Sheet T-003 in the CD-for forum question.rvt file.
The family file is Exit Sign - Ceiling Mounted.rfa
Thank you!
Message 6 of 10
Message 7 of 10
sleepy_samoyed
Hi, it still looked the same when printed as pdf.
My printing settings is as attached.
Thank you!
Message 8 of 10
Mike.FORM
Try exporting to pdf instead of printing.
Is the solid black in the family made using a filled region?
Message 9 of 10
SteveKStafford
FWIW, I downloaded your files and tried to replicate the issue. All the attempts to generate a PDF worked as expected, no strange graphics. It seems to be something unique to your computer/configuration?
Steve Stafford
Message 10 of 10
sleepy_samoyed
It is a solid black fill.
How do I export to pdf? I don't see the option here
Thank you!
