Need suggestion in making this family in revit
jaiganesh.venkatesan
Suggest which template will suit for this and give me a idea to work on the in revit family.
Generic model adaptive.
Kind of hard to advise you properly without knowing what is it, how it is going to be used, what method are you using to model it, etc.
I mean, I could suggest modeling it directly in the Project using a spiral Stair Type that only has one stringer and no treads or risers.  Catch my drift?
constantin.stroescu
a simple way could be by using Mass ...as follows:
Constantin Stroescu
Thankyou, its a kind of theming str.. behind that I going to make a lighting layer as same as the theming in  revit family. Problem is the theming is in CAD format. The str.. which i going to make is to be in rfa. format and to should be adjustable in future.
