Exterior layer wrapping in section
2 ANTWORTEN 2
Nachricht 1 von 3
m.kopaniaAQZ65
254 Aufrufe, 2 Antworten
I wonder is there any way to make exterior layer of the wall wrapping on the top of the window?
I have everything set up correctly and in the floor plan, on both sides of the window, last layer wraps correctly.
But why on earth the same thing does not happend on the top of the opening? Am I missing something?
It is rather obvious that when you finish the opening for window you put plaster all around, not only on sides.
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: m.kopaniaAQZ65
Wrapping defined in wall assembly only appears in plan.  If you want true 3d wrapping, create a shared column family wrap layer, nest it in the window or door family and associate parameters to match the opening dimension.  When place the window in the project, will join with the wall finish layer around the opening to create the wrapping.
Nachricht 3 von 3
Model the head wrap with a Floor Type of the same thickness and material as the finish.
