Need some advice on design options
5 REPLIES 5
352 Views, 5 Replies
I have looked at some of the videos that are online and they usually just show how to edit interior rooms or windows or Roofs. I have 2 options a client would like to see an l bend and a strait shed. Does anyone have any advice how to edit the main model so it will show these 2 options. I have attached the file that was working on which has the l bend option  and the shed roof option.
5 REPLIES 5
Redrunner92
Redrunner92
Do you want to make two different shapes for only the roofs or for the entire building's shape?
in reply to: Redrunner92
The entire building shape
Redrunner92
Redrunner92
Here is a sample of your model with design options applied.
The Help file is a good place to learn the basic functions of Design Options:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
To use Design Options, think of them as models within the main model. Make use of the design options buttons at the bottom of your screen:
The basic order I use is: first, create your model. Second, make your Design Options in the Design Options menu. Third, activate each design option using the drop-down box (where the middle arrow is pointing in the above image) and toggle off the "Active Only" check box. Fourth, add the items you want in the options using the "Add to Set" button which appears next to the drop-down box. Fifth, separately in each design option, delete the items you do not want in the active design option. When you delete an item in an option set it does not delete it from other option sets. Then, when you have finished setting up your design options, exit the options editor by selecting "Main Model" in the drop-down box.
Also I advise you learn about using Visibility/Graphics to control which Design Options show in different views (the Visibility/Graphics part is mentioned in the video around the 5:50 time mark):
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/worki...
I hope that helps!
I hope that helps!
I'll add that there is no Design Option Workflow without Dedicated Views.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
