- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
I need to export IFC in a specific coordinate system (I'm using survey point).
And I also need to export DWG files by using different set coordinates (that do not correspond to base, internal or survey points).
How can I achieve this?
Is it possible to define multiple survey points?
Or define null point manually for either export without it needing to be survey/internal?
