Need help with Roof
Need help with Roof
Message 1 of 10
Need help with Roof
Hi
I am trying to draw a roof to a single storey house with porch. My porch roof needs to be 300mm above the main roof. I am not getting it right and do not understand what I am doing wrong. Can anyone help me please? I am attaching a revit file and a picture.
Regards
Replies (9)
Message 2 of 10
Extend the porch roof to the main roof and use the join tool.  Over the part where there is no overhang, note that a roof boundary line has a height offset - adjust that so that it's the same level as the other eaves.
Message 3 of 10
Well, the problem you are having is that 300 doesn't work as you can see.  264.6 works though. Roofs will join nicely afterwards.
Message 4 of 10
constantin.stroescu
Is this what you want to achieve?
Constantin Stroescu
Message 5 of 10
Prettier Roof. What did you do?
Message 6 of 10
constantin.stroescu
I've made it in single Roof by Footprint , using a small trick .... introducing by using split element, of a small flat segment that will disconnect the porch part from the main roof ...
as shown in my screencast at min. 2.09 -3.15
https://knowledge.autodesk.com/community/screencast/709e27cf-35a0-4435-90fd-4735b04a7f48
Constantin Stroescu
Message 7 of 10
Yes, I use this technique often. I think I originally learned it from you.  After doing that, you can model the under-eave returns via the Roof by Extrusion method and then Join them to the Main Roof to remove the visible edges.
Message 8 of 10
constantin.stroescu
that's right!
Constantin Stroescu
Message 9 of 10
Hi Constantin
This is exactly I need. Thank you so much for your great help.
Regards
Parm
Message 10 of 10
Hi Barth
Thank you very much for your suggestions as well.
Regards
Parm
