Need help to add formula to SCHEDULE
nichkherbsman
Message 1 of 11
nichkherbsman
Good day. I need help if this is possible in schedule in revit. How to add this column to come up with this comment provided. Please see attached images.
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Replies (10)
Message 2 of 11
If you want to calculate how many LED lights per the light model length then create a calculated value integer  parameter, enter the formula:
Roundup ((Light Length - 24 mm) / 25 mm)
Message 3 of 11
nichkherbsman
How to I add this to the schedule? Can you give example my friend? I also attached revit file for you too review. Thank you
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Message 4 of 11
Message 5 of 11
nichkherbsman
Thank you for this, this is very nice. But I wonder if this kind of column possible to add. See images below.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Message 6 of 11
You have some light shorter than the 24 mm cap length, i.e. B_R7E = 19 mm.  If you still want to count them as one LED then use this formula:
if(Light Length < 37 mm, 1, roundup((Light Length - 12 mm) / 25 mm))
Message 7 of 11
I see what you want now.  What is the maximum LED length available?
Message 8 of 11
nichkherbsman
I think this 19mm will be deleted. But my problem is how do I create a formula that for actual length that will divide from drawing length. That the actual length with not exceed to 2m.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Message 9 of 11
nichkherbsman
Base on the comment, I also wonder what will be the basis for maximum length. I attach the complete table below
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Message 10 of 11
Attached is what I can do.  If you want to automatically divide a light into segments of different stock lengths then I suggest you actually split them in the model.
Message 11 of 11
nichkherbsman
This is very nice and thank you for this my friend. I will try your suggestion. By the way, why is it the Grand total not showing in sheet?
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
