need help on facade detailing
Message 1 of 14
so im trying to make tilted column effect on 8 story building facade which will continue on other two facades and i cant make it happen properly properly because i dont know how to make it look good on corners. it kinda looks janky. any suggestions ?
Replies (13)
Message 2 of 14
Post some pictures or something.
Message 3 of 14
constantin.stroescu
supposing that I understood your question, why don't you make a column that just goes from Level 0 to Level 8?
Constantin Stroescu
Message 4 of 14
that wouldn't look too "janky", @constantin.stroescu?  he, he.
P.S. I have no idea what "janky" looks like.  😉
Message 5 of 14
this is what i want to do but corners arent merged
Message 6 of 14
  i want something like this but corners needs to be merged and i have no idea how to model it
Message 7 of 14
are you referring to that white "sweep"?  How was it created?
Message 8 of 14
i created it with simple extrusion on each wall faces.
Message 9 of 14
Don't use Wall Sweeps. Sweep; yes. But, model it In-Place.  All of it.  Have you tried that?
Message 10 of 14
yeah ive tried it but sweep wont let me choose another plane for each wall  faces
Message 11 of 14
Draw Model Lines on each face first and then start In-Place Sweep and select the Model Lines for your Sweep Path.  Tried that?
Message 12 of 14
oh, i haven’t thought about that. ill try it. hope it’ll work
Message 13 of 14
Mass Form:
I couldn't get it to work as an In-Place Model.  It was Janky. Use In-Place Mass.
Message 14 of 14
oh, thanks for that. i actually tried in place mass but didnt achieved what i wanted. can you tell me me exactly what did you do ? i placed reference lines on each wall then set the plane drew rectangle and it swept along the lines but because of that plane i set at the begging it messed on other wall faces. your modeling looks just perfect
