Need help adjusting subcategory of an extrusion in custom Curtain Panel Family
jb3chen
jb3chen
Forgive my amateur Revit family making skills, but
I'm trying to change this extrusion type to a "glass" so that its line weight can be adjusted separately so that isn't as thick as the rest of the curtain panel, but am not sure where to find that option.
Curtain Panel? If so, change the Cut Line Weight of the Parent Category.
...go to Object Styles in the Family and add a Subcategory under Curtain Panel Category - then select the  geometry and assign it to the Subcategory.  Afterwards, reload Family into Project.
Create Family Subcategories | Revit | Autodesk Knowledge Network
...I see what's going on now.  Just edit the Family and assign the Panel Geometry to the existing "Glass"  Subcategory and then reload the Family into the Project.
jb3chen
Apologies for the late reply, but that helps! Turns out I just had to add a subcategory in the Family's Object Styles in order to be able to change it to Glass. Thank you!
