I have created a nice toposurface by linking to a .DWG, which is a slightly sanitized/redrawn direct download from cadmapper. Is there a way to bring the phony building extrusions into Revit as new conceptual mass? It is not sufficient to use the generic model method because I need a slightly higher LOD. Will explore a dynamo method only if necessary.
Rhino.inside.revit makes it very easy to do this but that program doesn't currently support subregion creation on linked topo so its not a full solution yet.
Thanks for your thoughts.
Revit is amazing
