Need advise on how to add intermediate vertical mullions on a window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Need advise on how to add four intermediate mullions to the attached family fixed window. Family Window originally out of the box had a cross vertical/horizontal mullion that I tried (unsuccessfully) to convert into the four vertical intermediate mullions, but although the window showed well on the building elevations the the family was loaded into the model, the new vertical mullions did not show on the building elevations. The vertical mullions could be about 1-1/2 wide to match more or less the exterior framing.
Instructions would be as simple as how to add one of the vertical mullions to the glass elevation of the family window (I tried but is not working out).
Will be great if the mullions can be relocated for other additional window dimensions.
The building is an "existing" building.
If you give instructions, I can follow that.
Thanks in advance.
