NBS Bim Object
Szigeti.Eduard
NBS Bim Object
Szigeti.Eduard
Hi all,
I have downloaded the suspended flooring with insulation BIM object and is downloaded as a Revit Project File.
I don't know how to use this file in my own project.
Can anyone please guide me?
Replies (10)
constantin.stroescu
in a new Project (with both projects opened), use Manage>Transfer Project Standards and choose from the Floors File only Floors..
Constantin Stroescu
Szigeti.Eduard
Thank you.
And from there?
Nothing happened
constantin.stroescu
  • the Floor types are loaded into your Project....you'll find them when you'll want to create a new Floor
  • but , if you want to insert the exact floors from your example , then use Copy/Paste function ...and the entire example thumbnails will be brought into your new project
Constantin Stroescu
Szigeti.Eduard
It is loaded in my project, but I still can't use it, or I don't know how.
I need to replace those steel beams that you see with this wooden structure
constantin.stroescu
you have a Beam System that sustains the Floor ...I suppose you haven't a loaded wooden Beam Family into your Project , so you have to load one from your Revit Library...
Have a look at my screencast (As I have not a loaded a Revit 2025 Library I've used a Revit 2021 Library)
frame str.mp4
Video Player is loading.
Current Time 0:00
Duration 4:29
Loaded: 0%
Stream Type LIVE
Remaining Time 4:29
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Constantin Stroescu
    Szigeti.Eduard
    Thank you very much for taking time to make a video, but I want to use BIM Objects, and this still not showing me how to use that BIM object I added as a first attachement.
    Loaded as Group into another Project. Now create a Floor just as you would create any Floor using one of the Floor Types loaded into Project.
    https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-A688CED0-E08C-4ED3-A8E8-14CBE78902BB
    constantin.stroescu
    if you expect that the Floors from the file you have downloaded ,to be true 3d Models then you will be disappointed..
    They are not , and they usually are so. Have a look at my screenshot  and you will see they are just materials...
    If you want to make a true 3 d Model then you have to proceed as I shown in my previous post (screencast) and use Parts for the Layers...
    how are your Floors made.:
    Constantin Stroescu
    Szigeti.Eduard
    Thank you
    Type a product name
