Navisworks exporter glitch, can't select options
isosa9APBT
isosa9APBT
I been working with the Navisworks exporter for a while and I haven't had any issues until now. I installed everything as normal for Revit 2025, Navisworks 2025 and the exporting utility. I did notice that for the new utility there are two files, the regular installer and a file ending with .7z. I have never seen that extension before. When I try to export my file from Revit and I go to the options button I can only see the check boxes and the fill sections. I did the exact same installation on two different computers with the same outcome. Has anyone experienced this?
vitorbortoncello
Install the Exporter 2025
https://www.autodesk.com/products/navisworks/3d-viewers?_ga=2.46138215.1128728288.1621788806-1177203...
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
isosa9APBT
That's what I did, that's the only way I know of to even have the option to export.
aubriegreen
Did you ever find a solution to your issue? I am currently experiencing the same glitch. I have uninstalled and reinstalled the exporter about three times now and still have not had any success in getting my options editor to work.
Savignano_TylerWhitfield
Community Visitor
Community Visitor
same issues here in 2023
isosa9APBT
Are your Revit programs up to date? I had issues that get solved once I update the software. They are currently working fine on all of my Revit versions and I honestly don't remember how it was fixed but I'm guessing an update did the trick.
