My section head is show detail number! I try to do it more time but detai number still not show number in section head!I have to something!help me!thanks!!!!!
Solved by chrisplyler. Go to Solution.
Hello
Have you placed your view on sheet and filled in Detail number for view?
I FIND DETAIL NUMBER LIKE ON THE PICTURE BUT IT HAVE NOT! I SET PARAMET DETAI NUMBER IN LABEL BUT IT NOT SHOW
Maybe there is something wrong in section head family. You need to edit it. First check the name of section head family that you are using.
Than find it in project browser and choose "Edit"
In family editor choose the label and make sure that it is showing Detail Number. Than upload family back to the project.
That's strange. It works fine in my model. Are you sure that you are using this family for Section tag?
Check again. I am certain that you have the TAIL family selected for both the head and the tail. Your Section is showing two tails.
CAN YOU SHOW ME HOW TO CREATE SECTION HEAD PERFECT!? I CHECK MORE TIME BUT STILL NOT SHOW WICH I WANT!PLEASE!THANKS!
That is showing correctly. What are you expecting different?
The numbers don't actually show up until you place the Section view onto a Sheet.
thank you!
@aleksei.tkachenko wrote:
Hello
