My revit crash when i change a level
kevin_bgentes
1,030 次查看
4 条回复
1 条消息(共 5 条)
kevin_bgentes
My project is kind of big. I have to change the top of my beams level. But since that level changes so many beams my revit crashes probably because my computer is to weak for that change. Do you have any idea i could change it without my computer crashing
0 个赞
已接受的解答 (1)
1,031 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
Avaris.
Add the beams to a model group, save model group, delete beams from project, change level, insert beams back in.
0 个赞
3 条消息(共 5 条)
kevin_bgentes
still crashes 😞
0 个赞
4 条消息(共 5 条)
Viveka_CD
Hi @kevin_bgentes
Welcome to the Autodesk community!
Sorry to hear that you are having issues.
Did the crash generate a CER?
0 个赞
5 条消息(共 5 条)
kevin_bgentes
已接受的解答
i guess my work computer just lack the power to do it. I worked around it be cuting most of the joist, change the level and paste aligned to level afterwards
0 个赞
