multiple temporary dimensions
2 REPLIES 2
Moshe-A
293 Views, 2 Replies
Guys,
As i go over the online-help i have i bump into this:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-7231A763-B95D-4F30-9EF4-D9C0B6301655
2. On the Options Bar, click Activate Dimensions.
    Note: System performance can significantly increase when the temporary dimensions and constraints are not displayed.
Is this logic or a mistake?
thanks
Moshe
2 REPLIES 2
loboarch
in reply to: Moshe-A
This note is more of a warning or caution in this case. Letting you know activating dimensions can reduce performance. It is perhaps worded in the reverse way.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Moshe-A
in reply to: loboarch
thanks Jeff
maybe the word 'not' should be dropped
Forma Design Contest
