Multiple Run Types Single Stair
BigPicture045
2,209 次查看
8 条回复
1 条消息(共 9 条)
BigPicture045
My stair is U-Shaped:
The top run has a different nosing profile than the bottom run. The top nosing profile extends to the front and the left:
Consequently, the bottom run automatically takes on the same run type and properties. I need the bottom run type to be nosing profile to be on the front only.
I am not able to duplicate and edit or select another run type because it is greyed out.
1. Is is possible to change the nosing profile properties for individual treads?
0 个赞
已接受的解答 (1)
2,210 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
RDAOU
@BigPicture045
Model them as 2 types. First run + the landing as 1 stair/type and a second from landing up
What's so bad about that?
 Individual nosing per tread?? Each step has a different nosing or each run?
If each run, then model 2  each with a run types, first run + the landing as 1 stair/type and a second from landing up
If each tread has a different nozing the you would be obliged to model them individually or convert the stair to generic model then convert that to parts and modify shapes
0 个赞
3 条消息(共 9 条)
BigPicture045
@RDAOU
How do you connect to the landing and ensure the same riser height?
0 个赞
4 条消息(共 9 条)
RDAOU
已接受的解答
copy stair to clip board the plaster same place...edit the first and remove top run, the edit the second and remove bottom run.  Edit type of either/or >>> duplicate type >> change nosing
0 个赞
5 条消息(共 9 条)
BigPicture045
When the duplicated stair is changed to another (identical - duplicated) stair, it loses the properties of the original stair. I guess the solution would be to manually adjust the top offset; however, this is not ideal. It would be nice to change the run type.
0 个赞
6 条消息(共 9 条)
What properties are lost?
0 个赞
7 条消息(共 9 条)
BigPicture045
@ToanDN
The riser height. See how low the first step is compared to the landing?
0 个赞
8 条消息(共 9 条)
No such problem here regardless where the landing is kept.
0 个赞
9 条消息(共 9 条)
RDAOU
@BigPicture045
That is quite odd...there is really nothing to mess up in this one Copy / Paste aligned / Edit / Select run / delete / repeat... See video below
0 个赞
