Multiple Run Types Single Stair
BigPicture045
Message 1 of 9
BigPicture045
My stair is U-Shaped:
The top run has a different nosing profile than the bottom run. The top nosing profile extends to the front and the left:
Consequently, the bottom run automatically takes on the same run type and properties. I need the bottom run type to be nosing profile to be on the front only.
I am not able to duplicate and edit or select another run type because it is greyed out.
1. Is is possible to change the nosing profile properties for individual treads?
Replies (8)
Message 2 of 9
RDAOU
@BigPicture045
Model them as 2 types. First run + the landing as 1 stair/type and a second from landing up
What's so bad about that?
 Individual nosing per tread?? Each step has a different nosing or each run?
If each run, then model 2  each with a run types, first run + the landing as 1 stair/type and a second from landing up
If each tread has a different nozing the you would be obliged to model them individually or convert the stair to generic model then convert that to parts and modify shapes
Message 3 of 9
BigPicture045
@RDAOU
How do you connect to the landing and ensure the same riser height?
Message 4 of 9
RDAOU
copy stair to clip board the plaster same place...edit the first and remove top run, the edit the second and remove bottom run.  Edit type of either/or >>> duplicate type >> change nosing
Message 5 of 9
BigPicture045
When the duplicated stair is changed to another (identical - duplicated) stair, it loses the properties of the original stair. I guess the solution would be to manually adjust the top offset; however, this is not ideal. It would be nice to change the run type.
Message 6 of 9
What properties are lost?
Message 7 of 9
BigPicture045
@ToanDN
The riser height. See how low the first step is compared to the landing?
Message 8 of 9
No such problem here regardless where the landing is kept.
Message 9 of 9
RDAOU
@BigPicture045
That is quite odd...there is really nothing to mess up in this one Copy / Paste aligned / Edit / Select run / delete / repeat... See video below
