Multiple project base points
Hi, I have 2 connected buildings with a bridge, each has it's own 0.00 level.
Is there a way to create 2 project base points? or any other way to show it?
Amit
martijn_pater
Are these two buildings attached as links in the file?
You can Link them both into one Project (or one into the other) and then reference their Survey Points.  Projects can only have one Project Base Point.  But, through Linking, a Project can have multiple Survey Points/"Shared Sites" established. Each Link's SP can be Visible in the View.    Are you familiar with this concept?
aung.khin
yes . same as this question
