- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a door which i'm trying to make into a smarter door than what we allready have. aka. I want several types of 3D elemets such as door handles to be able to be specified within the family parameters, to then be reflected in 3D and in a schedule within the project.
My problem is; I don't want a lot of Yes/no boxes. With all the options that i have (7 types og glass panels, several types of handles etc. etc.) there are going to be so many boxes I'm afraid that people may not use it as it can look complicated and be harder to use.
It may also cause people to make mistakes aka. selecting several handle types and not seeing it. yes i can code it in so that the shared parameter which is linked to the schedule says 'Multiple handle types selected', but if I want to do this to all the options i get an extremly long and complicated integrated IF statement.
The options as a solution to the problem i have could be;
1. Is there a formula which says ' If more than one chosen from the following parameters, this statement come up'
2. A drop down list of a specified set of options which is then linked to visibility only parameters for the 3D element ( much cleaner and prefered as it would have less yes/no boxes)
BUT i have searched and searched and can't find anything on this.
There are two options which are fairly close but doesnt seem to work;
-key schedule, but here I can't add shared parameters which is linked to the 3D elements within the door.
- Nesten family, but then I get the options of all the same family types, I only want the once I have specified.
Please help !
