Multiline Text Shared Parameter Combining Other Family Type Parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey Everyone,
I'm making wall/floor/roof tags that can act like Wall Assemblies boxes, so that if the assembly ever changes the tags at least graphically can update automatically (see attached).
For some reason we aren't able to collect actual material data (names, sizes, etc.) from wall families - or at least I haven't been able to find a way. The only way I can see to make a material list show up in the tag is to add a multiline text shared parameter to both the family and project, then manually type out each material as you see fit. The tag works fine when you edit the type properties of the family, but when you go to edit the multiline text parameter from the view the parameter adds the text data from other family type parameter - ie. Fire Rating, Sound Transmission, Type Mark, etc. (see attached)
Has anyone come across something like this or have any idea what's causing it? My only solution right now is to pin the tag (make it uneditable in the view) and edit from the family editor. And also hope that anyone else coming across it doesn't unpin and edit from view.
Dave
