Repeat the models
Repeat the models
hojukys
Repeat the models
hojukys
I made this model in a project.
I want to select this model and then repeat the same distances to make an underpass like the picture.
The above picture is my Revit model.
This is the final model I want to make.
How can I select and repeat in dynamo?
RSomppi
Why not use Copy or Array?
I would make it a structural framing family and place a beam system to create the repetition.
handjonathan
Hi @hojukys
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @ToanDN @RSomppi helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
