Imported image files to be exported to AutoCAD
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
jkirkorian
365 Aufrufe, 1 Antwort
Hello - I have a project where I need to import image files into my Revit 2022 project. Then I need to export CAD sheets for a Client. Is there a way to get those image files to export to the sheets in AutoCAD without the need for the linked path of that image? I have the external reference box unchecked when saving.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: jkirkorian
Sadly this is not possible in Revit. If you want to embed the image into the DWG without external image, this has to be done within AutoCAD itself. If you want to know how to embed image into the file, you have to copy the image using image editor and paste special and choose picture (metadata).
