Multi-sloped Roof
BigPicture045
Multi-sloped Roof
BigPicture045
Wanting to know the best way to tackle this roof. Can this be done using one roof?
Please see the original drawings for the roof:
The elevations keep getting flipped upside down regardless of any attempt to fix.
 What I've got so far:
Replies (27)
BigPicture045
The main issue I am having is the different sloped roof over the front right of the house. However, this slope does not continue all the way across, so I'm not sure how roof by extrusion would create this.
The roof above the front porch is about a 5.5/12, where as the main roof of the house which is also on the left side of the house is a 10/12.
syman2000
I would extend the 8/12 and 5.5/12 roof over to the main roof. Then do join geometry so you get the outline. After that you edit the main roof profile and then you pick the edge where the lower roof meet.
I see an 8/12 as well.
Post what you've got.  Also, do you have full Revit with Modify Sub-Elements Tools?
constantin.stroescu
I'd use :
  • a Roof by Footprint with Cut Off made at the level of the lower Roof ridge height
  • and the second Roof by Footprint on Top of the first one with the same slope as the bigger slope of it..
  • Finally Join the two roofs..
Constantin Stroescu
no shape editing necessary.
...but you can use alittle bit of everything one this one.   Defined Slopes, Roof by Extrusion, Slope Arrows.  Fun.
FWIW @BigPicture045 :
Shaped Edited using 3 Split Lines:
...if you have full Revit.
constantin.stroescu
illustrations of the method described in previous post:
Constantin Stroescu
Of course.  One roof by defined slopes.  No roof by extrusion, no vertical cut, no extra roof, no shape editing.
BigPicture045
For this project I am using Revit LT. I am unfamiliar with "shape editing" but from @barthbradley  post it seems that that is the tool for the job.
From what I can tell, the other answers used multiple roofs.  The main issue of combining the roofs is how they join together, especially on the right elevation.  I'm thinking I can modify how I use the fascia board to compensate for this.
Does it work with the 8/12s?
I would worry about that personally. But if you want it flush top and bottom, then use a thicker roof for the 5 1/2:12.
...of a thinner roof for the 10:12.  Six of one; half dozen of another I suppose.
BigPicture045
@barthbradley are you talking about the other side? I think this is one of those things I'm just going to have to do a lot of adjusting to get it right.
constantin.stroescu
it looks like the solution can be more simplified ....without Cut Off....as can be seen in my screencast:
https://knowledge.autodesk.com/community/screencast/5c1da266-169f-47bb-9593-135d0f92413f
Constantin Stroescu
yes
@BigPicture045
Marginally thicker 5-1/2 roof:
constantin.stroescu
and sections through the Roof ...2d and 3d:
Constantin Stroescu
BigPicture045
@ToanDN
Something got lost in translation. The above roof examples that have been posted are not based on the reference images nor the original roof plan. On the left side, the roof does not extend past the front gabled roof. It actually recedes a few inches.
@ToanDN When I try to modify the roof sketch, I get an error.
CorrectCorrectIncorrectIncorrect
Yes, it still keeps the rain out with 8:12s.
That is not my file.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
