Can't edit schedule properties
4 ANTWORTEN 4
Nachricht 1 von 5
FMORENORAMA
594 Aufrufe, 4 Antworten
I'm trying to edit existing schedule properties, but the dialog will not come up. As an alternative, I tried to create a new schedule, but it was not possible.
4 ANTWORTEN 4
Nachricht 2 von 5
PhilvK
als Antwort auf: FMORENORAMA
What do you see in the Properties window when you select the schedule in the Project Browser?
Nachricht 3 von 5
Lance.Coffey
Thank you for the question @FMORENORAMA, and welcome to the Autodesk forums!
If it looks like the schedule properties dialog is opening off-screen (i.e. the Ribbon grays out and you can’t do anything until hitting escape, but aren't seeing the dialog), try resetting the Revit interface: How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings
Lance Coffey
Technical Support Specialist
Nachricht 4 von 5
We're going to need a whole lot more words than."I tried to create a new schedule, but it was not possible" and "the dialog will not come up"?  Are you actually in Revit?
Nachricht 5 von 5
hmunsell
  • did you try double clicking on it in the project browser?
  • left clicking on a schedule in the project browser should bring up your Edit buttons
  • is it placed on a sheet?
    • if you double click on it on the sheet it should open as well.
    • also right click on it and pick Edit Schedule
i could keep going, but it would be nice to have some more information :strahlendes_Gesicht_mit_lächelnden_Augen:.
Howard Munsell
