- Mute
- Permalink
- Report
I have a large job that will have multiple architects stamping their portions of the work. Currently all the architectural team is working on the same architectural model. We are all using the same titleblock. The way the breakdown is working, each firm's work can be separated by sheets. So there does not need to be more than one stamp per sheet. But if we are using the same titleblock, when we go to put the stamp jpeg on the titleblock, that stamp will show on all sheets and not just on the sheets that they are responsible for. Is there a way to get multiple JPEG stamps on titleblock family that can easily be turned on / off? for example, on Sheet 1, person A's stamp can be on and then on sheet 2, person b's stamp can be on. And then can that on/off be handled with some filter or something within a view template so I don't have to go to each sheet to turn something on/ off? The only way I can think of doing this is duplicating the titleblock and renaming it slightly depending on who is going to stamp it. But since there are about two hundred architectural sheets, that will take a lot of time to fix each sheet.
