Moving wall issues with model.
jfjacques
jfjacques
Everytime I move an exterior wall in plan, exterior walls also seem to shift their elevation: top and bottom constraints seem to go haywire. This happens over and over.  I fix this by editing the walls profile, and then, strangely, resetting this profile afterwards. This is likely because some constraint is at fault -the software prompt comes up- but it seems this constraint keeps causing this issue over an over.
What is going on and how can it be fixed.
Don't attach walls to floors... I personally despise that function.
Editing profiles for elevation changes is a terrible idea too.  Use the properties and level offsets instead.
cbcarch
Besides Detaching Walls to Floor or Roofs, also look in an Elevation or Section and see if someone has a dimension which is locked from geometry to a Level or Reference Plan, or other geometry.
This can sometimes cause the problem you are experiencing as well.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Corsten.Au
Hello
When Wall is attached to floor or roof, you can always UNDERLAY upper floor while
editing and moving walls...
Other option for Roof is to use LW ( line work ) and keep upper level Roof always visible in
hidden lines etc..
Am also posting a Screencast showing a difference between Independent Roof and
Roof using Pick walls...
Using Pick walls options, roof gets adjusted automatically when you move walls...this helps a
lot if those walls are attached to roof and editing wall profile won't work all the time..
https://autode.sk/2OiEow9
Cheers
Corsten
Building Designer
