Masonry opening representation with a stacked wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mroble
378 Aufrufe, 4 Antworten
So, what I have, it a stacked wall. The upper portion is still evolving, but the lower portion is two courses of CMU, while the upper portion will be like a 6" stud wall.
So I drop a door onto my wall, and I get this....
Is there a way to automatically subtract 2" of CMU on both sides of a door? All doors, A door, anything in between?
Masonry opening should be 3'-4", not 3'-0" in this situation.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mroble
Edit the door family and make the opening cut wider to cover the entire frame.
Nachricht 3 von 5
mroble
als Antwort auf: ToanDN
@ToanDN
Actually, that worked.... BUT....
It leaves me with this gaping area.
Nachricht 4 von 5
Modify the door frame to cap off the opening.  Right now it is just trim pieces on top of the wall surfaces.
Nachricht 5 von 5
mroble
@ToanDN
Thank you sir!
I'm using the out of the box single door, and I was kind of shocked it wasn't built that way.
