Moving view crop ungroups detail groups
j0258169
Message 1 of 11
j0258169
For some reason, when I modify the crop region of a view, it breaks a detail group that I have in this view. This happens on some views only, not all. And for the views where it does happen, it happens consistently. But in those views, it also doesn't break all detail groups, just some. The same detail group placed in other views behaves fine. The detail group has no constraints to model geometry. I can't seem to figure out why it behaves this way.. Any ideas?
Replies (10)
Message 2 of 11
Having exactly the same issue, very frustrating. I've tried ungrouping and re-grouping but it doesn't help.
Message 3 of 11
DNP0
Having the same issue here with Revit 2020 (can't recall encountering this issue before).  When attempting to adjust the view's crop region (either manually or with the boundary editing command) an error "Fix Groups" message is generated indicating that certain detail groups within the view will be either ungrouped or need to be duplicated.  The issue doesn't seem to occur with any consistency and doesn't seem to be related to a particular detail item within the group.  So far, when the issue has occurred the low-level workaround has been to copy (CTRL-C) the view's detail groups, then delete the view's detail groups from the view to allow the crop region to be adjusted with the error, then paste-in-place the copied content after adjusting the crop region....PITA.
Message 4 of 11
bart.koevoet
What works for now is cutting the group (ctrl+x), then drag the crop, and then paste the group aligned where it was.
Message 5 of 11
sta69D29
Hi.
I have come here looking fot the same answer, just to realize there's no answer. 😞
Yet, I did a few trial and error, and seem to have found what's causing the problem. Apparently you can't use constrains inside the group or you'll get this bug.
I managed to fix it by removing all constrains from my group. Hope it helps you all as well. 🙂
Cheers
Message 6 of 11
jono.won
A solution is to move the detail group away from its original position and then move it back.
After doing this, you can edit the crop without the detail group changing.
What i do is select the detail group, move it away by pressing the arrow key once (any direction) and then the opposite direction. Basically moving it back and forth.
This is for Revit 2022.1 FYI.
Hope this helps.
Message 7 of 11
Shane_Fitz
I'm still encountering this issue in Revit 2024.  It seems to mostly relate to detail items with an instance parameter, in my case it's a line based family that tries to resize itself when the view extents are changed.
Message 8 of 11
DNP0
Still having the same problem; however, it appears that detail groups that include line-based families might be more prone to "breaking" than those without?  The issue seems to be reduced (or potentially eliminated?) if you can modify the detail group by replacing the "line-based" families with an equivalent family that's based on the standard "detail item" family.  Might be worth a try...although, it might not be the most optimal solution.
Message 9 of 11
SteveKStafford
Can you share a file that is having this issue? I haven't been able to reproduce it using Revit 2025.
Steve Stafford
Message 10 of 11
Studioearl
Still happening in R26,
I'm copying and pasting Revit notes about it. Please forgive formatting/spelling/grammar.
DETAIL GROUPS BREAKING WHEN VIEW EXTENTS CHANGED
  • This Is An Intermittent Problem When Changing The Clip Depth, Crop Region, Or Uncropping A View. You Get An Error
Group instances of the same type do not contain identical members.  Press "Fix Groups..." to select from options to make the groups consistent.
Corresponding group members in different group instances diverge in the following respects:
- different curves
  • FIX GROUP IS BAD; CANCEL WHEN ASKED TO FIX
  • WORK AROUND
    • SELECT ALL DETAIL COMPONENTS AND GROUPS (Can Use A Working Template With Only These Things Visible; Makes It Easy To Isolate And Select Them)
    • CUT THE SELECTED
    • MAKE VIEW EXTENT CHANGES
    • PASTE ALIGNED SAME PLACE
Hope this helps some.
Message 11 of 11
bart.koevoet
Yes, as I've said: "What works for now is cutting the group (ctrl+x), then drag the crop, and then paste the group aligned where it was."
