Moving Sheets from one Revit project to another
tstewart
Message 1 of 8
tstewart
How to move a cover sheet and other sheets from one project to another in Revit 2024?
Accepted solutions (3)
Replies (7)
Message 2 of 8
vitorbortoncello
Insert views from file
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
tstewart
The original Coversheet has multiple Viewports, so everything is not coming over to the new Coversheet. How to copy the entire sheet to the new file?
Message 4 of 8
You can insert sheet from another project if there are no model views or legends on the sheet.  What do you have on the sheet?
Message 5 of 8
tstewart
There are Model view and Legends. How can I insert the entire sheet as is into another sheet?
TS
Message 6 of 8
TS
You cannot.  Create a PDF and import/link the PDF in the other model, or just include the PDF in your PDF package.
Message 7 of 8
mhiserZFHXS
Its pretty obvious why model views can't be transferred... The model in the original doesn't exist in the new project.
Message 8 of 8
tstewart
I was trying to avoid creating it as a PDF because I have to edit it.
Thank you,
TS
