How to move a cover sheet and other sheets from one project to another in Revit 2024?
Solved by ToanDN. Go to Solution.
Solved by tstewart. Go to Solution.
The original Coversheet has multiple Viewports, so everything is not coming over to the new Coversheet. How to copy the entire sheet to the new file?
You can insert sheet from another project if there are no model views or legends on the sheet. What do you have on the sheet?
Its pretty obvious why model views can't be transferred... The model in the original doesn't exist in the new project.
