Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How to move a cover sheet and other sheets from one project to another in Revit 2024?
Insert views from file
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
Autodesk Certified Professional
The original Coversheet has multiple Viewports, so everything is not coming over to the new Coversheet. How to copy the entire sheet to the new file?
You can insert sheet from another project if there are no model views or legends on the sheet. What do you have on the sheet?
@tstewart wrote:
There are Model view and Legends. How can I insert the entire sheet as is into another sheet?
TS
You cannot. Create a PDF and import/link the PDF in the other model, or just include the PDF in your PDF package.
Its pretty obvious why model views can't be transferred... The model in the original doesn't exist in the new project.
