moving project away from the internal origin
Hi, I have a question regarding the internal origin. Started to build my projects and levels without setting up correct distance from the sea level. Now I want to move entire project 90.3 meters above the sea level, I have used "relocate the project" and "specify coordinates at point" to move it up, but it only moved the survey point down by 90.3 m. Levels shows correct elevations but the problem starts when I want to create a toposurface which reference the internal orgin. It appears 90.3 meter above. Is there a way to move project 90.3m up from the orgin point ?
