Moving multiple views from one sheet to another, at once
I am organizing multiple callout views on a final sheet. I have a group that need to be moved to another sheet because there isn't enough room now. Instead of moving each view one by one, is there a way to move all of them simultaneously? I'm just wondering so it wont be very time consuming to move them one by one.
you can drag and drop views from and to different sheets in the Project Browser, but doing multiples at a time and keeping their placement the same on the different sheet cannot be done using this method -- or any that I know of.
chrisplyler
If you want to move ALL the views from one sheet to another...just change the sheet number/name instead.
@chrisplyler wrote:
If you want to move ALL more than half of the total the views from one sheet to another...just change the sheet number/name instead.
FIFY
chrisplyler
Sorry. I mean that if you don't want to individually move any, but if instead your purpose is to move everything from one sheet to another, for example because you forgot a sheet that should come ahead and now you want to insert it...you can instead just renumber the existing sheet to a later number and then create your new sheet with the earlier number.
@chrisplyler
I know what you meant and we are on the same boat.  What I was trying to say is If I have 20 views on a sheet and 11 of them need to move to another one, I would renumber the original sheet and move 9 to a new sheet instead.
chrisplyler
Yeah that would be the most efficient process.
