Different project north for plan views
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1684 Aufrufe, 3 Antworten
Hi, I should overlay survey to the site plan, so I should be able to read the codes, but in other plan views, I need to rotate the Project north 180 degrees, because that gives me better layout. So, can I have different project north for different views? Thanks for help
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Project North is PROJECT North - not VIEW North. So, unfortunately, no.
Nachricht 3 von 4
@Anonymous
You cannot have more than one Project North in a Project as @barthbradley said.
But you can rotate view's crop region to orient the view as needed.  Easiest way is to create Scope Box, rotate it (reversed direction of how you want the view to rotate), and assign it to the view.
Nachricht 4 von 4
als Antwort auf: ToanDN
Thank you,
