I need some guidance on project base point, survey point, shared coordinates etc.
I've read so many tutorials and videos, I'm not even sure I've done it right, but my brain is fried for sure. Bear with me for a moment, I'll explain the different steps I took and I'd really appreciate if you could help me!
Basically, I started by developing the building model (we didn't have the survey cad yet). Now that I have the cad file, I've made the site model. First, I tried following tutorials, by linking cad files, acquire coordinates etc. I determined the X,Y position of one specific corner of the site boundariesin Autocad, then changed the survey point coordinates accordingly. Same in the building model. When I tried copying grid lines from the building model to the site model (eventually I want to use this site model with topography, levels and grids as a base for other consultants), they didn't place at the correct location. I must have done something wrong with survey point or the base point. At that point I gave up.
After that, I decided to create the site model from the building model. I deleted everything but the grids and levels. This is probably not the right way to approach site model, but frustration made me do it.
In the site model, I did the same steps again, to aquire the coordinates from the cad file. Linked the building model, which had to be placed at the exact same spot since survey, base point and origin are identical. Then shared the site coordinates to the building model, and I'm not even sure I got it right!
Now, I made a topography in the site model, but I need to move the linked building model up, to meet the real site. Is this something I do in the building model or just by moving the link? I would say in the model. But can you do it in the site model by moving the linked model and somehow changes the linked model automatically?
Apologies for the messy description but I hope you can help!!
I'm pretty confident with revit in general, but when it comes to site stuff, I'm a novice.
