Hello. Sir/ Madam
Good day to you. This Hayley who learn the Revit in my college.
I have a problem with delete the value of color fill legend.
Please find the photo as I attached.
Would you be able to let me know how I reset the all values and put new one?
Thank you for your supporting.
Best Regard.
Hayley
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von bin. Gehe zur Lösung
Find the room (either in the project or in the room schedule) and delete the information in the Department parameter.
You could just select and apply the color you want using the button on the color field.
Hello. Thank you for your reply. Actually my value of color fill legend not work properly so I would like to reset and add new value. but I can't delete them as see below.
Would you be able to let me know how can I solve it?
try post your file here? so we can check. thanks
@Anonymousby reset you mean to the original color? Let me understand so I can help you
Hello, Thank you so much for your kindly advise.
I just would like to apply other color on floor but I couldn't.
If I make new legend, the name should be "No colors define" but my one is "Ensuit".
Also, I can't apply my new legend (Floor) on my drawing. That's why I would like to reset all and make them again.
Do you have any idea to solve it?
