Move position of parameter in family
marco.defina
marco.defina
here in the image below is highlighted the button to move the parameter.
If i have 100 parameter is so boring move every single parameter with 100 click of mouse...It's a faster way to move???
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Alfredo_Medina
Have you tried the other buttons on the right side? Sorting from A to Z, or vice versa?
marco.defina
I know but i din't want to have the parameter A to Z..
Sahay_R
Parameters are sorted alphabetically. Rename them with a number in the order that you want to see them.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
marco.defina
Rename it's not an option, To many families and to many parameters, shared parameters that in one family, it should be in another order.
My question is, if exist a way to use for example a button of the keyboard as shortcut instead the mouse click? Or better select 10 parameter and move together?
Ho capito il tuo problema, purtroppo no. Anche perchè Revit Pone i parametri in base a categorie, se stanno tutti ficcati in Other (Altro) o dimensions per dire te li ritrovi tutti e cento li. al massimo cerca di fare un raggruppamento di categorie settandoli tu nei vari moduli interni della famiglia (identità, dimensioni, vincoli ecc). poi te li ritrovi belli organizzati nella famiglia caricata nel progetto. Spero di averti aiutato, per qualsiasi cosa rispondi.
Caed9
There should be a dragging option like in excel.
I don't even bother sharing it on Ideas as they most likely ignore them.
