Create arrow-dimension
Message 1 of 10
Hello!
I'm trying to create a dimension in Revit with just an Arrow and the text. No leader line apart from a short line under the text. I have drawn how I want it to look. Thanks!
Best regards,
John
Replies (9)
Message 2 of 10
Instead of using a dimension, create a line based detail family with label reading the line length and symbol as what you want.
Message 3 of 10
Thank you! Is that the only way it can be done? I think I have used one template a long time ago where I could choose Annotate, Aligned and then I just chose a type that worked just like I want now. If I do it like you say, where do I find the detail family in the project and is it used like a ordinary dimension?
Message 4 of 10
Actually you can use a custom Ordinate dimension type.
Message 5 of 10
Ok! Do you know which settings I should use to get it to work like I want? I have tried to customize but it’s pretty complicated. I have also tried to Google it without any luck. The main problem I have is that I don’t know how to get the text placed to the side and to cut the leader line so it just have one end. Thanks!
Message 6 of 10
See the attached file.
By the way, the screenshot above shows most of the settings you need to have.  See a screencast in a few minutes.
Message 7 of 10
erik_thorselius
pilmåttsättning.pngIs there any way you could check the distance so that the text gets the desired offset from the "witness line" directly without having to move the text manually, and connect the length of the "dimension line" to the length of the text.
Message 8 of 10
No on both queries. Sorry.
Message 9 of 10
Maybe use a line based detail family so you have more control of the graphics.
Message 10 of 10
MaríaSager
Thanks for the video! It's really useful.
May I ask if you know if there's a way to automatically move the text further to the left, as you did manually on the video? I saw the option to give it vertical offset, what I'm asking is if there's a horizontal offset setting somewhere I'm not seeing.
Thanks in advance and greetings!
