Move and select dimension between split views
alexanderEO
alexanderEO
How can I select and move the dimension that appears between a split crop view, and change its parameters?
The cropped views are carefully splitted and cropped, I dont want to redo this every time I place a dimension.
RDAOU
@alexanderEO
It is not clear what you mean by move and what elements are you dimensioning from/to.
Dimension strings cannot be moved. They are constrained by their witness lines. IE: you need to
  • either drag the witness lines to another ref. element
  • or move the model elements hosting the witness lines
alexanderEO
Any solution to this?
I want to replace the dimension with text "according to floor plans".
