Hey @millerew17
@drahthaar wrote:
The building pads are right under the footings (light gray) When I select the lower pad in consistent colors I see a faint blue highlight going straight down? Seems like it should be going up?
It is more or less the same issue you had with the building pad on the front Porch...You have too many Building Pads placed
Sorry for my earlier comment ...but on mobile I couldn"t see any pad highlighted
- Go to your 3D View
- On the Properties palette enable section box
- Grab the shape handle of the section box and drag it to cut through the house (use shaded view - easier to Identify offending elements)
- You have 2 pads on top of each other 1 at level First Floor and the new one at the retaining/foundation level which you have placed in the above images
- Delete the one on top (that on the first floor
That should sort out the issue inside the crawlspace
Edit Start: one more thing .. Pads do have a built in floor/slab structure. If you are using that for some purpore then you will need to set the pad either at a lower level that can absorb the thickness of that layer or use Offset = to the thickness of the building's ground floor/slab (Similar to your other post..otherwise you will have two overlapping slabs and that Grey Matter) Edit End
[I have 2015 LT but figured I learn the basics on this 13 version. This project and the last one you helped me on will be it for 2013. I'll get the subscription as time and money warrants. Everybody has a story!] I am very grateful for the help on this forum.
Basics are the same mate 2013 or 2017 .... better if you practice on the later version...it has more to offer and you will get the hang of it (the software's new look) better 🙂
If you dont want to invest much...The same books/tutorials can be found in public libraries and university libraries (at least over here they are) ...ie: more or less free access might be useful
Cheers
