Monolithic stairs not formed correctly
protikkayal
protikkayal
Hi everyone,
Anybody have the solution for the issue with not correctly formed of curved monolithic stair?
If I try to create monolithic stair to a curved shape it forms, but some of its portion become invisible in different views, but assembled stair have no such problem(see the snap below). Stair Issue.jpg
Anyone have any solutions, please share.
Thanks.
Change the bottom to stepped instead of sloped.
Corsten.Au
check this out.. its not to fix the monolithic stairs but to achieve similar result cause of curved design..
https://forums.autodesk.com/t5/revit-architecture-forum/curved-stairs-landing-problem/td-p/7412926
Corsten
Building Designer
Short answer is this shouldn't happen, but it does and is a glitch for monolithic stairs.
Possible solutions: Either change to a different stair type, change the underside to stepped, or you can make an in-place family using the 'Stair' category. For something as simple as you're showing, an in-place sweep seems the easiest, as long as you only need in modeled correctly and don't need automatic stair numbering or path annotation or those kinds of things that come with OOTB stairs.
