Curved Stairs landing Problem
 Hy..
I Have always a  problem with curved Stair.. i have this warning message "Can't make monolithic stairs"
Can you help me to no where is the problème?
Corsten.Au
Hi
Check the attached updated stairs in Revit.
I have resolved it..so you can see the missing bit..
you can also use other type of staircase,  ( not monolithic ), and use stringer to act like curved concrete looks like monolith.
Cheers!
Corsten
Building Designer
HI Ganesh..
Thank you for your reply. But I find that this type of staircase still has to be corrected in revit, to be simpler to execute.
Smiley Wink
