Avoid suppression of a view by mistake
Message 1 of 9
I would like to know if there is a way of preventing someone else to delete a specific view by mistake at the project browser in Revit. Is there a way of locking or pining a view at the project browser?
I appreciate your attention!
Replies (8)
Message 2 of 9
Sahay_R
You can pin the view onto a sheet, but if you delete it in the Project Browser, that won't help. So TBMOK - I don't think it's possible.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
Open Worksets, Views and see if you can lock it like with user worksets.
Message 4 of 9
Hello Rina,
Thank you for your answer. However, I need a solution to prevent someone else deleting (by mistake) a specific view at the project browser not in a sheet.
Message 5 of 9
Hi Toan
We tested that before and It doesn’t work. Thank you for your attention.
Message 6 of 9
@Anonymous wrote:
Hi Toan
Are you sure?  If I make a view Editable under my name then other users cannot delete it until I choose to Relinquish it.
Message 7 of 9
loboarch
@Anonymous wrote:
Hi Toan
 I think this will work. Make a change to the view to a local file with a Revit session logged in with a user name you make just for locking. Then close/sync the local file making sure to NOT check in borrowed elements. Now the view will remain locked. un-alterable/un-delete able except when someone logs back in with the user name who has it checked out.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 8 of 9
its not really revit-y and it seems tricky otherwise...... why not just include in the view title some text like........ 'view title - DO NOT DELETE'
Message 9 of 9
Sahay_R
I learned something new and will keep this in mind for future reference. Thank you, gentlemen!
Rina Sahay
