hello,
i'm trying to export do DWF in order to batch print more easily,
in DESIGN REVIEW i set the option "chose paper source by DWG page size", supposedly this would print the drawing exactly has it was defined in REVIT, but it tuns out that the program reduces the scale of the drawing "ZOOM FACTOR"
what can i do?
Hi @Anonymous
This can be due to the fact that there are not enough resources (such as memory) to process a drawing or batch print. Restarting Revit often restores sufficient system resources to enable the successful continuation of the batch print job.
Let us know if any of the settings and recommendations mentioned above helps resolve your issue.
Please mark this response as "Accept as Solution" if it answers your question to help other members seeking similar solutions. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
hello,
no problem here with the system resources...
but i think i've discovered the problem, when exporting revit doesn't consider the print margins of the sheets, when printing on Design Review, if i choose the "use paper size of file" it reduces the drawing to compensate the margins...
Hi @Anonymous
I've tested batch printing and it's prints fine with margins and proper drawing size for me, I just wanted to verify.
Can you send me your log file for the batch print?
The log file is named BatchPrintLog.txt. It resides in the following location:
I would be happy to take a look if you would like to post a sample file for troubleshooting. Let me know and I can share a private folder for you to upload.
Viveka CD
hello viveka,
i'm not batch printing (because revit doesn't support Hp Designjet 1050c plotters), i'm exporting to DWF in order to batch print in Design Review
Hi @Anonymous
I wanted to verify that exporting to dwf and batch printing in Design Review works fine too. I've tested this on two machines - one with updates installed and it works fine and one without current updates failed to batch print with errors.
As mentioned earlier, you can share the file so that we can test for issues. Let me know and I can send you a folder to upload. Glad to help!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Viveka CD
