Module a Stair Landing Shap
engineerjaber87
Message 1 of 12
engineerjaber87
Dear
I am moduling a steel Stair Structure consist of C Shape Plate as a Tread with Concrete Finish
i design the Tread and add concrete using Model in Place Generic Model, but i am Facing to Module the C Shape for Landing anyone have Idea how to Model the LAnding as a C Shape Plate
Replies (11)
Message 2 of 12
alan.johnson7YLND
Have you got an image of what you are trying to achieve?
Message 3 of 12
engineerjaber87
as you can see in the attached picture the steps is a C Shape Steel while Lading i am not able to choose a C shape only rectangular Shape
Message 4 of 12
alan.johnson7YLND
I couldn't see a way to do the landing as a C shape (like your image) using the Stair tool.
But like you said you are adding the concrete finish as model in place, I would remove the Landing tread in stair and then just model in place a C shape and then a concrete finish.
You can Tab select the landing and turn off the tread.
Message 5 of 12
Post your File instead.  I'll take a whack at it. I think it can be done with the Stair Tool as one Assembled Stair.
Message 6 of 12
engineerjaber87
the File isze is around 400 Mega Bite, it is inside the full modeling steel structure Building
Message 7 of 12
Can you at least provide some construction info?  I mean, I'm trying to figure out why you can't model your stairs with the Stair Tool.  I think you should be able to. Maybe I'm wrong. Maybe YOUR stairs cannot be modeled with the Revit Stair Tool.
Message 8 of 12
engineerjaber87
I have attached the star seperatly, please look into it, as the steps is C Shape while the Landing i want it C Shape as well and the concrete topping i will apply it as model in Place , is it correct like that ?
Message 9 of 12
alan.johnson7YLND
Model In Place works for me
Message 10 of 12
engineerjaber87
Thank you Alan
i think you right this is the only is to disable the landing and model it in place
Message 11 of 12
ARRGH. Best I could do keeping the landing as part of the stair assembly.  If only we had both a front and rear nosing option.  Maybe it's on the Roadmap?  😉
Message 12 of 12
engineerjaber87
But the Back side will Remain Straight,
the stair Option Should be More flexible With Autodesk as for now it is limited
