Modifying the wall profile in plan
mostafamohamedtaher99
How can I make this wall in plan? I tried creating an In-Place mass then modeling wall by face but it just kept popping up errors, and I don't want to create it using model in place because I want it to appear in schedule. Any help?
tmCL9N6
You could make a generic model that only contains a void extrusion.
Make sure its set to "cut with voids when loaded".
Then you can cut the wall with the generic model.
RDAOU
@mostafamohamedtaher99
Model In-Place with a Void Extrusion (Set Category to wall or generic ... not Mass) ...
Use CUT before you finish the inplace instance
Another approach...
Does it subtract from the volume of the wall in schedules?
RDAOU
Yes it does .. the cut portion will be deducted from the volume
Thank you so much that helped.
